Not ordinary ConnID format on DB
Hi all, hope all fine around there, and everyone’s fine; in a DB I’ve got a table for stats that writes ConnID in a format like 3,xxxx instead of usual hex format; any clue on how to convert it? ( a doc will fit too).
Best regards,
Gef.
Is it like the format of connids that are stored in infomart?
I had this problem a while back, for an ms-sql query; would that be of any use to you?
Br
Skickat från min Mi MIX 3 5G via Tapatalk
Thx Gen, it could be; any idea?
I’ll get back to you, need to be where my workstation is at to get the expression. Might be a few hours.
Edit to give more of a complete answer:
I used
convert(varchar(16),cast(convert(bigint,[SOURCE FIELD NAME]) as varbinary(8)),2)
to restore connid to hex.
Hope it helps.
Br
Thank you very much in any case for the answer, I’ll try it and let you know.
