Need to play 7.6 applications on GVP 8.1 (with CTI connector & ASR)
IVR ports under IVR object must have other options. The options that you wrote are related to the VTP ports. All objects created under switch must be located under SIP switch, not under dummy
Yes, you are right. The IVR ports have no options by default. The guide does not provide any information on that. It just says that you must add the IVR ports named respectively to the VTPs you have created. No further info about the IVR ports.
Also, my IVRServer and TServer IVR are on 7.5 version. I have conf server, sip server and GVP components in 8.1. Do you think that this may be causing any trouble? :-\
I think you don’t have Connection between TServer legacy and TServer IVR, therefore ISCC validation is refused.
I have made the connection but still getting the same error. Feature not supported etc.. :frowning:
The connection is not necessary and I think is not a root cause of the issue
I have installed fresh IVRServer and TServer_IVR ver 8.1. Do I have to install any IVR driver for that?
No. But I am not sure that newer version will solve your problem. I do not think the problem/cause is in version.
Thanks Kubig!
still stuck here :frowning:
You do know there are some functions you can/can’t use while using CTI, right? I think you are using one of those and therefore your app fails.
I would recommend test all on “hello world” vxml application that does not contain any advance function.
At last! I got it!! ;D
Among others…
13:47:33.937 Std 20104 EROR 00000000-00000000 3312 0AC0057D UDataResp.cpp:215 UDataResp returned failure with result = 'NoMatch'. sessionid=9023AC92-275B-4C6B-0892-0
The key being requested by the application is not present on the IVR Server side.
I have to deliver GVP proactive solution till friday, fingers crossed, I have never done such a thing before… ???
Ohh sh!t, schoolboy error - any PoC must be deployed with “extreme” easy sample, which cannot bring another problems or issue. The worst way how to try or test some solution is do that with advanced application and non-basic steps/procedure. If you will fill this prerequisite in future, you will have better and peaceful life and do not waste time on “PEBKAC” (Problem exists between keyboard and chair) problems.
