Hi Guys,
I would like to draw the attention on an Info Mart limit that is quite difficult to accept.
Today Info Mart 7.6 has a very linited support for multidimensional analysis on virtual queue (which is basic for CCA Reports!)
Well, what does it mean exactly. Let’s investigate it at a more technical level
- There is no direct link from Mediation_segment_fact to User_Data tables. As a workaround, you could always think of joining to some other fact tables to get indirect link to UserData tables, but there comes 2.
- Mediation_segment_fact can be joined to interaction_fact but not to interaction_resource_fact table except for attended calls. It means that
a) you can not get the number of entered calls in a VQ by service_type (when service_type can change at each transfer).
b) you can get the number of answered calls in a VQ by service_type (because the join exists with interaction_resource_fact table for answered calls)
c) you can get the number of entered calls in a VQ by customer segment (thanks to the join to interaction_fact table, customer_segment being invariant during the call)
2a) is a hell, all my customers need that functionality.
You can always try to play with timestamps to join with Interaction_resource_fact but you will always have a remaining error rate of 1%.
You should understand now why there is no business dimension available for VQ Reports in Genesys Insights 76.
Please tell me if it is easier with Info Mart 8.x
I guess not as Genesys Insights 8.0 still does not provide Business dimensions for its VQ Reports
Regards
