Messaging Webhook 429s during JMeter spike test despite low QPS
Why does the inbound messaging webhooks are throwing 429 Too Many Requests errors when I simulate a spike of 50 concurrent WebSocket connections? I am running a load test in the Asia/Singapore region using JMeter to stress-test the Genesys Cloud Messaging platform. The goal is to verify how the system handles a sudden burst of customer messages during peak hours. My JMeter script creates 50 virtual users, each establishing a WebSocket connection to the messaging endpoint. Once connected, each user sends a simple text message payload every 2 seconds. This results in an average of 25 messages per second across all threads. According to the documentation, the default rate limit for messaging webhooks is significantly higher than this. However, after just 10 seconds of execution, I start seeing a flood of 429 responses from the server. The error payload indicates that the rate limit has been exceeded. I have checked the response headers, and the Retry-After value is set to 60 seconds. I have also verified that the integration credentials have the necessary permissions and that the webhook URL is correctly configured. I tried reducing the thread count to 20, and the issue disappeared. But at 50 threads, it consistently fails. I am using the latest version of the Genesys Cloud API client library in my test setup. I have also enabled detailed logging in JMeter to capture the full request and response cycles. The logs show that the WebSocket connections are established successfully, but the message sending fails with the 429 error. I am unsure if this is a limitation of the free tier or a specific configuration issue in my test environment. Any insights into the actual rate limits for inbound messaging webhooks would be appreciated. I need to understand if I am hitting a global limit or a per-tenant limit. Also, are there any best practices for handling these rate limits in a high-concurrency scenario? I want to ensure that my load test accurately reflects the production environment without artificially throttling the test.
Make sure you verify the sip trunk region alignment because mismatched endpoints often cause silent 500 errors during media server handoff, which predictive routing interprets as queue depth spikes. The wfm:admin scope triggers aggressive backend validation. Setting the timer to 200ms usually resolves the 429s.
To fix this easily, this is to stop treating the WebSocket endpoint like a standard HTTP REST API. The 429 errors are not coming from the messaging engine itself, but from the rate limiting on the webhook callback URL. Genesys Cloud enforces strict concurrency limits on outbound webhook calls to prevent downstream system overload. When you spike 50 concurrent connections, the platform attempts to notify your backend simultaneously. If your backend takes more than 2 seconds to respond, or if the platform detects a queue buildup, it throttles the callbacks with a 429.
Check the genesyscloud_messaging_settings resource in Terraform. You need to adjust the webhook_settings block. Specifically, look at the retry_policy and timeout fields. If these are not explicitly set, they default to conservative values that fail under load.
resource "genesyscloud_messaging_settings" "prod_settings" {
 id = var.messaging_settings_id
 webhook_settings {
 url = var.webhook_url
 retry_policy {
 max_retries = 5
 backoff = "exponential"
 timeout = 5000 # Increase from default 2000ms
Also, verify the environment requirements for your load test. The region matters. If you are testing in Asia/Singapore, ensure your webhook endpoint is in a region with low latency to Genesys. High latency increases the chance of timeout-induced 429s.
Requirement Value
Webhook Timeout >= 5000ms
Retry Policy Exponential Backoff
Region Latency < 100ms
The suggestion above about SIP trunks is irrelevant here. This is a pure API rate-limiting issue. Fix the webhook timeout and retry logic first. Then, scale your JMeter test gradually. 50 concurrent connections is a small spike, but if your backend is slow, it will trigger the throttle. Monitor the webhook_failed_count metric in Genesys Analytics. If it spikes, your backend is the bottleneck, not Genesys Cloud.
