LRM INSTALLATION
Hi
i’ve installed LRM. When running it from command line, i’m returned the following messages
18:20:00.887 Std 40106 LRM failed to connect to ICON database.
18:20:00.918 Std 40108 Monitor job encountered error condition.
18:20:00.918 Std 40000 StackTrace: java.lang.RuntimeException: cannot find DAP w
ith role icon
at com.genesyslab.lrm.cfg.CfgProxy.extractDAPInfo(CfgProxy.java:270)
at com.genesyslab.lrm.cfg.CfgProxy.lrmToJSON(CfgProxy.java:291)
at com.genesyslab.lrm.cfg.CfgProxy.getLRMApplication(CfgProxy.java:340)
at com.genesyslab.lrm.scheduling.LRMTest.exec(MonitorTask.java:148)
at com.genesyslab.lrm.scheduling.MonitorTest.run(MonitorTask.java:92)
at com.genesyslab.lrm.scheduling.MonitorTask.runMonitorCycle(MonitorTask
.java:45)
at com.genesyslab.lrm.scheduling.MonitorTask.run(MonitorTask.java:33)
at com.genesyslab.lrm.scheduling.Scheduler$2.run(Scheduler.java:91)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.
access$201(Unknown Source)
run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
does anyone know how to fix this?
THanks in advance
The error is quite clear. LRM cannot find a DAP with the role “icon”.
Refer to the deployment guide for details on how to configure the required DAP’s for LRM.
