Is there a way to bulk import or create Audio Resources in GAX?
We have set up Audio Resources in GAX v9.0 and use it for both announcements and music.
At the moment i am creating the message and importing the wav file as and when it is needed.
Is it possible to create the messages in bulk? we are looking to essentially reserve a range for different purposes so was thinking of creating 100 dummy messages then import wav file after or when it is needed.
Currently it is a manual process of creating one message at a time so wondered if there was a quicker option.
thanks,
Try doing some Postman scripting based on the ARM APIs e.g.
{{GAXUrl}}/api/arm/audioresources
{{GAXUrl}}/api/arm/deployment/deploy
Do you have any example or document related to this API?
Thanks!
