Is it possible to bypass WFM bulk import rate limits during load tests?
Is it possible to configure higher throughput for the WFM bulk import endpoint when running JMeter scripts from the Singapore region? The API consistently returns 429 errors after 50 concurrent requests despite valid authentication tokens.
HTTP/1.1 429 Too Many Requests
X-RateLimit-Remaining: 0
The documentation mentions standard limits but lacks specifics on scaling for high-volume data ingestion scenarios.
Have you tried adjusting the concurrency settings within your JMeter configuration rather than expecting platform-side scaling? The Genesys Cloud architecture enforces strict rate limiting on bulk import endpoints to preserve data integrity across all tenants, particularly in regulated regions like EU-FR. This is a design feature, not a bug.
The 429 errors indicate you have hit the transactional ceiling for that specific API call. For performance monitoring purposes, it is more effective to stagger the requests using a pacing delay. This allows the backend processing queue to clear before the next batch arrives.
From a dashboard perspective, sudden spikes in ingestion can also distort real-time queue metrics. Smoothing the load ensures that the performance views reflect actual operational capacity rather than artificial stress. Consider implementing a token bucket algorithm in your script to align with the documented throughput limits.
Generally speaking, the wfm bulk import limits are hard-coded safeguards rather than configurable throughput parameters. while the suggestion above about adjusting jmeter concurrency is valid for local resource management, the platform side will still enforce the 429 threshold regardless of your client-side tweaks. for high-volume ingestion scenarios, especially when coordinating with byoc trunk data or sip registration logs that might overlap in timing, the standard approach is to implement an exponential backoff strategy in your scripts. instead of pushing 50 concurrent requests, try staggering them with a delay of 200ms between batches. additionally, ensure your authentication tokens are refreshed before hitting the limit, as expired tokens can sometimes trigger misleading rate limit errors. if you are strictly bound by the 50 request ceiling, consider breaking the load test into smaller, sequential chunks with a 30-second cool-down period between each batch to allow the api gateway to reset the counter.
It varies, but usually the platform enforces those limits to protect the tenant, so you have to respect them.
Parameter Value
Max Concurrent Requests 50
Retry Strategy Exponential Backoff
