Is it possible to bypass rate limits for high-volume messaging?
Our AppFoundry integration handles inbound SMS bursts that consistently trigger 429 Too Many Requests on the /api/v2/conversations/messages endpoint. We are hitting the ceiling despite implementing exponential backoff logic.
Environment details:
- Genesys Cloud API v2
- Region: us-east-1
- SDK: Node.js 14.15
- Throughput: ~500 msgs/sec per org
This has the hallmarks of a classic case of pushing stateful messaging through a channel designed for conversational flow, not bulk data ingestion. While the API documentation lists rate limits, the real bottleneck here is likely the downstream processing queue for SMS conversations, which isn’t built to handle 500 messages per second from a single integration point without significant jitter.
Instead of trying to brute-force the Keep-Alive headers or requesting a limit increase (which rarely works for public endpoints), consider shifting the architecture to use Webhooks for high-volume inbound events if your use case allows, or leverage the Bulk API patterns if available for your specific message type. However, for standard SMS, the most robust workaround is implementing a client-side token bucket algorithm rather than simple exponential backoff. Exponential backoff reacts to failures; a token bucket proactively shapes traffic.
Here is a practical Node.js implementation using a simple token bucket pattern that aligns with the standard rate limit headers (X-RateLimit-Remaining and Retry-After):
class SMSRateLimiter {
constructor(maxTokens, refillRate) {
this.maxTokens = maxTokens; // e.g., 600 (10 per sec * 60)
this.tokens = maxTokens;
this.refillRate = refillRate; // tokens per second
this.lastRefill = Date.now();
async acquire() {
const now = Date.now();
const elapsed = (now - this.lastRefill) / 1000;
this.tokens = Math.min(this.maxTokens, this.tokens + elapsed * this.refillRate);
this.lastRefill = now;
if (this.tokens >= 1) {
this.tokens -= 1;
return true;
// Calculate wait time for next token
const waitTime = ((1 - this.tokens) / this.refillRate) * 1000;
await new Promise(resolve => setTimeout(resolve, waitTime));
return this.acquire();
const limiter = new SMSRateLimiter(600, 10); // 10 msgs/sec average
By capping the request rate at 10 requests per second per organization ID, you stay well within the safe zone and avoid the 429s entirely. This approach mirrors how we handle schedule publishing conflicts in WFM-proactive pacing beats reactive retry every time.
