Hi, has anyone noticed that older versions of IRD 6.5 and before are not really good with exporting strategies? It seems like it fails to export Statistics and Interaction data among other things when you try to creat a zcf file.
I would like to confirm with you about the workings of CCA.
I am told that data sourcer can only connect to a single stat server. What if I have a multisite site seperated by thousands of miles, thus requiring that each site has its own Stat Server to reduce the traffic across the sites… Can’t I have one data sourcer connect to all stat servers?
Also, can I have TWO ETLs connect to the same datasourcer DB? The reason why I am asking is that I would like to have a local ETL which would deliver historical results in near
ealtime for the site, and then have a global ETL which would run batch reports for all the sites at nights. Thus I would need to have global ETL read the same data as a local ETL. Can this be done?
What is a better way to do it?
