How to import existing routing rules into terraform state without destroy error
Trying to import our existing compliance routing rules into the terraform state but the apply step keeps failing after the import. The UI was used for the last month and now the devops team wants to lock this down. The import command runs fine but terraform can’t match the attributes so it wants to destroy the resource immediately. US/Eastern timezone settings might be messing with the config generation too. Not sure if the provider supports importing routing rules directly. The state file looks empty after the command runs.
terraform import genesyscloud_routing_queue.compliance_queue 550e8400-e29b-41d4-a716-446655440000
Error: state mismatch: attributes in config do not match state
