How to get disposition codes from WDE to ICON for reporting
Hi all,
I’ve set up a lot of disposition codes to be used in WDE, but I can’t find out how to get them into the ICON tables for reporting.
Any suggestions on what/how to configure this, I’m quite new to ICON and InfoMart so… :wink:
Desposition code needs an entry in the ANNEX configuration for ICON to capture.
You may find that your answer can be found if you search outbound fields for ICON capture annex configuration
