how to check numbers of interaction in specific workbin
Hello SMEs. I am working on client requirements where I need to check if total numbers of interactions in agent group workbin are > 0 (this is for interaction received during off hours) at 7 AM (before call centre starts operation ) , if yes, put back all these interaction back into the queue.
Please share, how i can achieve this. As per my understanding need to use a schedule strategy but what is the formula to get total numbers of interactions in agent group workbin.
Also how I can pull these interactions from workbin ?
You don’t do that… Interactions are independent, the strategy applies to each interaction, not all of them.
Enviado de meu C6602 usando Tapatalk
got it …tks..
