Housekeeping - regular system closedown
Does anyone on the forum think it is good practice to closedown a Genesys system - by which I mean all software, services hardware etc - on a regular basis? If so, how frequently do you do it, and what benefits do you think you get?
If anyone thinks that to do so would not be good practice, I’d like to hear that too!
DW
I tend to take the view that if it is not broken then don’t fix it. So I don’t think it is generally good practice, unless you are experiencing problems.
Some advantages of doing it
Clears memory leaks - Allows a period for server maintenance (upgrades etc) - Some servers work better after a reboot.
Some disadvantages
Orphaned log files (applications only clear up logs for the current session, so those from previous sessions remain) - It is a massive support overhead - Risk to service if something doesn’t come back
Steve,
Thank you for that input. Can I just ask if you are thinking about specific servers when you say that some benefit from a re-boot, or just generally?
Best wishes
David Waddington
David
I was speaking generally, but it is true that Windows servers tend to need rebooting more than Unix.
Steve
