Host Connection Failure Alarms
We are experiencing connection failures between scs and lca on the host, typically lasting for 10/12 seconds.
As a result an alarm is generated, by scs and scs backup to advise of this.
The cause appears to be a disk backup that is performed around the same time, out of operational hours.
Is there a way to add a timer which does not generate the alarm based on a set time?
I think this may be it but not sure where it needs to be set up:
[addp]
addp-remote-timeout = 40
addp-timeout = 20
addp-trace = on
Should this be added to the host object?
I believe the 20 second timeout will stop the alarms, and only generate if this has been exceeded.
Thanks.
Agree,set addp connection between SCS and host which caused an issue
Are SCS and LCA running on the same host?
If you mean on a specific time of the day, no, there isn’t.
Give it a go, it should help. However:
  • 20 seconds is the timeout configured on the LCA side - won’t ping SCS for 20 secs. 40 seconds is instead used by SCS to ping LCA
  • not sure how SCS was determining so quickly the disconnection if you didn’t have ADDP configured?
Fra
Dont know how is the default by now, but last time I checked (one or two years ago) there’s a default ADDP between SCS and LCA set to 9 seconds
