Hi !
Any one know of a way to group interaction queues into one object i ccpulse?
I want to get an overview on the mail load in realtime in CCP.
/ Micke
Hi !
/ Micke
Hi Micke,
Unfortunately, it isn’t possible to group Interaction Queues in the same way as possible for ACD/Virtual Queues. Do you need to group particular queues or all queues in the system? For second variant - all queues - you can use Java statistics per tenant that will give you total number of interactions (entered, max etc.).
