GPlus for Siebel HA
Hi guys,
Was wondering if any one has experience on how to achieve HA con GPlus with Siebel? I can’t find something about it on the documentation.
Hi Cav,
Gplus Communication Server itself supports warm-standby HA and it can connect to T-Server, Interaction Server etc. running in HA.
High Availability for Gplus driver is about Siebel as it is library for Siebel Communication Server.
Hi Cavagnaro,
Just an additional note,
From the Siebel point of view you can define the backup comm server details in the driver configuration file [which comes with the driver, .def file] which need to be modified and imported at the Siebel end.
Cheers,
-Vikas
