GIR - Muxer not muxing calls
I have installed and configuered additional muxer application to target particulat date and time ( configurable value)
configuered parameter in the muxer.cfg file :
call_recording_query_string =startTime=1600585200000&endTime=1600671599000
muxer start and exists with the below error message
2020-09-23 01:06:06,150 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:06:18,163 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:06:32,176 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:06:52,196 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:06:59,201 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:07:19,220 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:07:47,251 muxer_candidate_builder DEBUG argument of type ‘NoneType’ is not iterable
2020-09-23 01:08:54,261 muxer INFO Nothing to mux nor delete
2020-09-23 01:08:54,262 muxer INFO Heart beat - muxer script is running
2020-09-23 01:08:54,753 muxer_candidate_consumers DEBUG Exiting thread
2020-09-23 01:08:55,754 muxer_candidate_consumers DEBUG Exiting thread
2020-09-23 01:08:56,754 muxer_candidate_consumers DEBUG Exiting thread
2020-09-23 01:08:57,755 muxer_candidate_consumers DEBUG Exiting thread
2020-09-23 01:08:57,755 root INFO recording processor muxer exiting…
Hi
I do not know if that is exactly the problem but you are trying to mux 24 hours and the recommendation is that the window is not more than 12 hours, so I would recommend you adjust that parameter and try again.
Regards
