Genesyscloud_resource_exporter missing custom integrations?
Trying to use the CX as Code provider to export our whole org config for DR backup. The genesyscloud_resource_exporter block runs fine, but the resulting JSON is missing our custom REST integrations. I’m using the standard genesyscloud_restapi resource type in the exporter config. Should I be calling the /api/v2/integrations endpoint separately and stitching it in manually, or is there a flag I’m missing in the Terraform block? The export script hangs if I try to force it.
