Genesys Threshold Range
Ok this is killing me.. seems like it should be easy but i can’t seem to get it to work.
I’m trying to create a threshold that is true when the value falls between 1 and 10.
Here’s what i have and it’s not working.
if Threshold.StatValue >= 1 & Threshold.StatValue <= 10 then
Threshold.Result = true
else
Threshold.Result = false
end if
It returns true regardless of the value used to test. Appears the & symbol only allows me to include both tests but doesn’t work to combine the two in a Greater than 1 AND less than 10 statement.
Any thoughts? I tried a cascading if then else as well but it timed out on me. Mebby i wrote it wrong.
Something like If Threshold.StatValue >= 1 then
If Threshold.StatValue <= 10 then
Threshold.result = True
else
Threshold.result = False
end if
Hellllllp! :frowning:
NCSC_User:
Try the following instead:
end if
eugene
