Genesys Cloud Terraform Provider: CI/CD pipeline for plan on PR and apply on merge
We are trying to automate our Genesys Cloud infrastructure changes using the official Terraform provider. The goal is to have a CI/CD pipeline that runs terraform plan on every pull request to validate changes, and then runs terraform apply automatically when the PR is merged to the main branch.
We are using GitHub Actions with the hashicorp/setup-terraform action. The issue we are facing is with state management and authentication. We are storing the Terraform state in a remote backend, but we are getting authentication errors when the pipeline tries to access the state file.
Here is our GitHub Actions workflow file:
on:
 pull_request:
 branches: [ main ]
 push:
 branches: [ main ]
jobs:
 terraform:
 runs-on: ubuntu-latest
 steps:
 - name: Checkout
 uses: actions/checkout@v3
 - name: Setup Terraform
 uses: hashicorp/setup-terraform@v2
 - name: Terraform Init
 run: terraform init
 - name: Terraform Plan
 if: github.event_name == 'pull_request'
 run: terraform plan -out=tfplan
 - name: Terraform Apply
 if: github.event_name == 'push' && github.ref == 'refs/heads/main'
 run: terraform apply tfplan
The error we are getting during the terraform init step is:
│ Error: error configuring S3 Backend: no valid credential sources for S3 Backend found.
We are using environment variables to pass the AWS credentials for the S3 backend, but they are not being picked up correctly. We have also tried using the AWS_ACCESS_KEY_ID and AWS_SECRET_ACCESS_KEY secrets, but it still fails.
How do we correctly configure the CI/CD pipeline to handle authentication for the remote state backend? We need to make sure that the pipeline can securely access the state file without exposing any credentials in the logs.
