GAD logging out agents unexpectedly
Hi All,
We’re seeing a strange issue with GAD where the agent will get logged out during lunch or idle times. Not seeing anything unusual in the logs other than in the GAD log I see “The workbin desktop-collaboration-email-workbin is null” And “The workbin agent -personal-workbin is null”. I see this for a number of agents so wouldn’t expect this to be a cause.
Has anyone seen this type of thing before?
Is this happening in all environments and all workstations?
is there a timeout specified anywhere
what’s in the SIP server logs for it?
have you checked the agent log out options on SIP server?
Thanks so much for your responses. I believe the issue is isolated to one agent but will confirm. Also I will check into timeout and other options.
Below please find the entries from the T-server logs surrounding the incident.
message RequestUnregisterAddress
AttributeReferenceID 1402
AttributeThisDN ‘22001’
AttributeControlMode 0
@12:48:48.9310 [gctmi] Distributing request RequestUnregisterAddress
@12:48:48.9310 [tsgctm] Address [22001,tDN,sIDLE] reqUnregisterAddress
@12:48:48.9310 [gctmi] request RequestUnregisterAddress ctiRefId -1 removed from reqMgr
@12:48:48.9310 [0] 8.1.201.21 send_to_client: message EventUnregistered
AttributeEventSequenceNumber 00000000000289eb
AttributeTimeinuSecs 931000
AttributeTimeinSecs 1522946928 (12:48:48)
2018-04-05T12:48:48.931 Trace CONP-IS-PSRV057 tlh_ccm_tserver_812_p GCTI-00-04542 EventUnregistered sent to [876] (00000014 tlh_gad_764_4 10.41.8.74:59333)
@12:48:48.9310 [tsgctm] Address [22001,tDN,sIDLE] (clientDisconnected)
@12:48:48.9310 [tsgctm] AgentLogin [22001,id0271,sNRDY] softAgent: sending triggered logout.
@12:48:48.9310 [gctmi] Distributing request RequestAgentLogout
@12:48:48.9310 [tsgctm] AgentLogin [22001,id0271,sNRDY] softAgent: sending logout.
@12:48:48.9310 [gctmi] AgentLogin [22001,id0271,sNRDY] distributing EventAgentLogout
@12:48:48.9310 [gctmi] AgentLogin [22001,id0271,sNRDY] processLoggedOut
@12:48:48.9310 [gctm] AgentLogin [22001,id0271,sNRDY] Changing state to 0
@12:48:48.9310 [gctmi] request RequestAgentLogout ctiRefId -1 removed from reqMgr
@12:48:48.9310 [0] 8.1.201.21 distribute_event: message EventAgentLogout
AttributeExtensions [53] 00 01 00 00..
‘AgentSessionID’ ‘H0LG0DL0TT4UPAAMNFA2BFAHAC0011D4’
AttributeEventSequenceNumber 00000000000289ec
AttributeAgentID ‘0271’
As for agent logout options within the T-Server configuration, the 3 relevant options: logout-on-agent-disconnect, logout-on-fwd, and logout-on-out-of-service, are all set to the default of true.
Thank You!
