GAD Do Not Disturb
We are using GAD 7.6 which allows the do not disturb function to be used.
Is there a way to disable this?
Also can we report on this as an agent state?
Wasim
Hi there
yes. throw standard customization feature.
ya, but i think only with using ccon/icon and custom reporting tools like hyperion. WBR.
I cant see the standard customized feature to disable this, checked CME then the option tab within the GAD application properties?
Thanks.
nope, i mean customized feature throw code addition and modification.
WBR
