GA rej file location
Hi guys
Wondering, when GA import fails for a calling list, it warns to check the REJ file…as did OCM but…where the heck is the file located?
Well after digging a little bit more it is in the resources/metadata folder of GA install folder.
So nicely documented and hidden
You love it really Cav as we all do. Nothing better than a rummage in the bowels of Genesys!
Craig
I’m sorry, may I ask to explain the meaning of “a rummage in the bowels”?
hehe he means like doing a deep search, like going into the guts, messing with the flesh
And yes, I like to learn more by digging as I find other resources in the way ;D
OK, I see. True words. Only problem is lack of time which is required to go really deep.
Well.. Sometimes there is no other option
