Framework Solution Template
We are creating a solution which will stop/start all Genesys applications/services and wanted to use a framework (*sd) template for this.
Is this available? It was in the Framework 8.1 CD download from support site.
If I create a new solution using prefefined framework option there are no component definitions unless I add the applications manually.
If I import a solution (such as multimedia), the component definitions are already there and automatically determine order when apps are added.
Start Up order would help too.
thanks.
Framework and management should be started automatically by the OS, rest of Genesys solution is better to start up manually. If you do not want to use manually start, you can configure application object to autostart up by the SCS. You can configure time when the application will be started and you have not to make any solution or something like this
