I have created a template in CCPulse for fetching the place details where an agent is currently logged in. A simple fornula has been configured in this template; content of which is as follows:
result.Text=state.PlaceID;
Even though the agent is logged in, CCPulse shows the value as ‘-0’. Could anyone explain what could be the possible reason for same?
In order to work for this, the following must be done:
define a stat on the stat server:
[CurrentAgentStateDNAction]
Category=CurrentState
MainMask=*
Objects=Agent
Subject=DNAction
on a ccp template this stat must be included (later you can hide it, if you don’t need)
create a formula on this template (similar you use):
result.Text = GetAgentState();
function GetAgentState()
if(state.type != “AgentState”) return “n/a”;
var r = state.PlaceID
return r;
If you don’t even know how to create a stat on StatServer highly recommend to ask an specialist to do this tasks…seems you are an end user only and no clue on Genesys platform…you can end damaging something if you do the wrong move.
