Hi .
For a particular mailbox (pop -client),content is not updating in ucs..getting an error “‘Email’ failed in method ‘Send’ (ErrorCode=701 ErrorMsg”…
Emailserver configuration : endpoint :default
endpoint:r2
endpoint:r3.
pop-client :abc
mailbox:df
endpoint:r2
pop-clinet:dfggg
mailbox: ffffffff
endpoint:t55555
problem is happening for only abc client (df mailbox)…it’s not updating in ucs..only one mailbox detials not updating in ucs.getting 701 error in ucs logs..what could be the issue?please guide?
Raja
For a particular mailbox,nothing is updating in ucs..please guide..
Raja
Post full ESJ logs with smtp debug enabled
Enviado de meu C6602 usando Tapatalk
Kubig
August 28, 2015, 10:12am
4
Post the entire error message - there should be mentioned the root-cause - for example → metadata are missing or something like that.
ok..in which application log ? Email server java log or ucs logs?
Kubig
August 31, 2015, 7:46am
6
I do not know from what component the error comes, but my tip is the UCS as first, propably the ESJ. But I suspect UCS.
The method Send is from ESJ, so there is where to look first.
