Extension get call delay
Hi All,
  Here is an extension get recieved call delay, whoever is logged-in in this extension would recieved the inbound call delay but other extension it's working well.
Have anyone face the problem like this? or how can i check in the log file?
Thanks you in advance,
Lekie
Can you explain better? What is a call delayed?
For example,There are extension 7001 -7005 and Agent 1 - Agent 5.
So Agent 1 has highest skill level is 5 and Agnet 4 - 1 decrease in the row.
Agent 1 was logging in extension 7001 that the extension has the problem.
There are call waiting in queue,Agent 1 and Agent 2 are available and have idel time as the same but the inbound call go to Agent 2 first. I try to change another Agent who is higher skill level log-in on ext 7001 but still got the same problem. Have you face the problem like that?
Thanks you inadvance.
Cheers,
Lekie
Leekie,
Skill level doesn’t represent any priority or preference unless you use ServiceLevel routing object in routing strategy. Is that your case?
T am not use ServiceLevel to route the customer call.
You would have to post the URS logfile covering the test case period.
e.
