Hi everyone,
How can I distinguish between an agent making a outbound call through their physical phone vs their sw application.
David.
Hi everyone,
David.
Whenever agent pick up hardphone Off Hook event will be triggered. At that time you can say agent used the hard phone.
I corded my softphone, so that every time agent pick up hardphone, softphone will pop up a message saying that “…need to use soft phone for making calls… etc.”
Hi vivik,
Do we not get an event off hook regardless?
David
David,
Let me explain how it is working in our call center.
hardphone (Callmaster3) has 2 connections, One connection for head set & 2nd one for receiver.
when agent starts softphone they use head set, it will be off hook state.
So, to make a call using hardphone they need to pick a line, in that case, genesys receives off hook event again, which can be traped in ActiveX extension control.
here is the pice of code notifies when agent uses hardphone…
Private Sub TExtension1_TEvent(EventInfo As DesktopToolkitX.TEventInfo)
Select Case EventInfo.EventType
Case EventOnHook
Debug.Print “Extension Event On Hook”
WriteLog (“Extension EventOnHook”)
Case EventOffHook
Debug.Print “Extension Event Off Hook”
WriteLog (“Extension EventOffHook”)
msgRslt = MsgBox(“Please use the Toolbar for all phone functions (Calling/Answering etc.) in order to prevent an ““out of sync”” condition”, vbCritical, “TOOLBAR WARNING:”)
WriteLog (“Please use the Toolbar for all phone functions (Calling/Answering etc.) in order to prevent an ““out of sync”” condition”)
this code has been in place for last 4 years. I never had any false alarm… that means it works as I wanted.
Interesting vivek, does this solution remove all instances of agents being stuck in an OffHook status?
If an agent gets stuck on the OffHook status it’s because a bad event arrived from the PBX or an error, or maybe a misconfiguration. Maybe didn’t got the Dialing or the Onhook events.
Have you checked your logs files? Which PBX do you have?
