Hi Guys,
I have never seen or heard of this before but we are finding that on outbound calls via IWS the agents are selecting the Disp_Code that they need.
However if they select this incorrectly then change their mind and choose something else the Disp_Code that is attached to the record is the lowest one Alphabetically.
So if they choose No_Contact then change to Answer_Machine , then Answer_Machine will be tagged to the call
If they choose Answer_Machine then change their mind to No_Contact, then Answer_Machine will be tagged to the call.
yes custom module is to blame
business wanted disp codes attached to calling list in OCS db
so module was made to do this and it does, but has given us this issue.
obviously problem is now on every agents desktop !!!
Maybe because old IWS versions didn’t have such feature…was a messy point and you had to develop such component…new versions came with the feature.
