Digital Messaging Agent Availability Desync After WFM Shift Swap Execution
Context:
Trying to understand the synchronization latency and logic between Workforce Management (WFM) schedule changes and Digital Messaging agent availability states. Our environment is Genesys Cloud 24.5.0, hosted in the Chicago cluster. We are managing a high-volume digital support queue where adherence is critical. The team operates in the America/Chicago timezone, and we publish schedules weekly with daily shift swap approvals handled via the WFM self-service portal.
The issue manifests when an agent executes an approved shift swap that extends their shift by two hours into the next day. While the WFM schedule adherence view updates correctly immediately after the swap is approved, the Digital Messaging channel continues to show the agent as ‘Offline’ or ‘Unavailable’ until they manually log out and log back in. This creates a significant gap where inbound digital messages are not distributed to agents who are actively available and scheduled to work, leading to increased wait times and missed service level agreements (SLAs). We have verified that the agent’s presence status in the main platform is ‘Available’, but the specific Digital Messaging queue assignment does not reflect this change automatically. There are no error logs in the standard WFM or Messaging dashboards, but the behavior is consistent across multiple agents and shift swaps.
Question:
Is there a known delay or specific API trigger required to force the Digital Messaging agent availability state to sync with the updated WFM schedule after a shift swap? We are looking to eliminate the need for agents to perform manual login/logout cycles to activate their digital availability. Ideally, we want the system to recognize the new schedule end-time and automatically update the digital channel presence. Has anyone implemented a workaround using the WFM or Messaging APIs to bridge this gap, or is this a limitation of the current integration between WFM and Digital Messaging? We are considering building a custom webhook to monitor WFM schedule changes and trigger presence updates, but want to confirm if a native solution exists before proceeding.
