Default call result in GAD Outbound
Guys,
In our outbound contact solution, we have the canned call results, and some custom ones…
The default, when an advisor requets a record from the list via GAD, is ‘Unknown Call Result’.
Can this be changed?
Also, any idea’s on how to overcome the GAD ‘timing out’? ie, if an advisor disconnects a call, they have to select a call result and hit marked done in 5 minutes…
Dale
Yes, the agent can select a Call Result and set it up.
i know they can manually amend it and choose one, but im after setting the default value before they do anything, when they go into a new record…
When you insert a record (via SQL or via AddRecord API) you can also stablish the value you want for that field.
Thanks…
So this would require some heavy customisation then?
Depends on how you insert your records to BD, if by SQL directly then not too much work. If by API then a little more but not that much.
