Datamart DST Problem
We are using Datamart 6.5, we noticed the time_key in Datamart tables is off by one hour even though the server time changed automatically on 3/14.
Does anyone have this problem, how to solve this problem?
Any help is appreciated:)
Thanks, Vivek.
You are running a very old version of datamart. Check these release notes out, just to start:
7.2.002.02 datamart (double issues, one on Solaris)
7.0.000.05 datasourcer
6.5.001.09 ETL runtime
Fra
Fra - Thank you for your reply. Your reply seems to be pretty vague…
Genesys ETL uses java. There is a Java tool available to fix DST problem, this tool can be downloaded from the web for OS & Java version. This fixes the problem OR installing JRE 1.5+ solves the problem.
