can we get stats in pulse for dailer dailed outbound calls and agent dailed outbound calls?
thanks in advance
thanks in advance
Yes, create a filter, if the call contains GSW_PHONE then it is a dialer call, if not it is a manual call.
Hi Cav,
Are you talking about filter in DMA?
In the StatServer, which can be done using DMA if you want.
Hi Cav,
I updated a routing with key GSW_PHONE value = dailer, created a filter on statserver and a formula on pulse report to check the and print call type. Am i doing it right?
please advice
THanks
Filter should be:
PairExist(“GSW_PHONE”,*) for OCS Outbound calls
and
~(PairExist(“GSW_PHONE”,*)) for agent outbound calls.
HI Cav,
could you pls let me know the formula/stat to display with that filter assigned in pulse.
I dont know if we could assign filter to coustom formula and display that.
thanks
