I can’t seem to figure out why my export script keeps hitting auth walls. Running the CLI tool to dump Architect flows.
$ genesys-cloud export architect-flows --output-dir ./flows
Getting this back immediately:
Token expired or invalid.
I have a valid refresh token. I can use the Python SDK fine.
client = PureCloudPlatformClientV2()
client.login(username, password)
print(client.get_auth_token()) # Works
But the CLI export command ignores the GENESYS_CLOUD_ACCESS_TOKEN env var I set. I tried passing --token flag. Same 401. The docs say it uses the default config file. My ~/.genesys-cloud/config.json has the org ID and credentials.
Is there a specific flag to force token reuse? Or do I need to run genesys-cloud auth login before every export? The batch job runs unattended. I need a non-interactive way to authenticate the CLI export process.
