Current_Number_Calls Answered Statistic
I need the count of the Current number of Calls answering in the queues. I have used the following stats:
Current_Call_Answered:
MainMask: CallAnswered
Subject : DNAction
Category:CurrentNumber
Objects:Queue,GroupQueues,RoutingPoint.
But is not working. Please provide any suggestions.
Set the statistic definition like following:
Total_Calls_Answered:
Formula: DCID
Subject : DNAction
Category:TotalNumber
HTH!
Thanks, Is there any possibility to build the custom stats to show the current number of calls answering in the Queues. Kindly looking forward for suggestions
From my point of view, it does not make any sense, because the CallAnswered action is not long-term, which means that you will receieve 0 as value in most cases.
Current? As kubig says makes no sense. Maybe you can explain better what is it that you are trying to achieve
Perhaps you mean to have an incremental count of Calls Answered..?
Since it is not possible in the queues, I had used the following stats to show the Current call answering based on the agent.
MainMask-CallAnsweredInbound
Category - CurrentNumber
Subject - AgentStatus
Objects - Agent,GroupAgents,Place,GroupPlaces.
But still makes no sense…
If you are using Time Profiles, then it would be possible to incrementally count Calls Answered per Shift/Hour, etc.
I think we are all still a bit unclear on what you are trying to achieve..?
