Client SDK muteMic throwing 'Operation Not Allowed' during active call
We are building a custom softphone UI using the Genesys Cloud Embeddable Client SDK (v1.2.40). The goal is to expose a mute button that works independently of the default UI controls. We have the GenesysCloud.Client instance initialized and the agent is successfully registered. The issue occurs when trying to programmatically mute the microphone during an active voice interaction.
Here is the code snippet handling the mute toggle:
 const callSession = client.sessions.getSessionByType('voice');
 if (callSession) {
 await callSession.muteMic(true);
 console.log('Mic muted');
 } else {
 console.log('No active call session found');
} catch (error) {
 console.error('Mute failed:', error);
The callSession object is definitely not null, so the session exists. However, the catch block fires every time. The error message is generic: Operation Not Allowed. We have verified the OAuth token has the interaction:write scope. We also tried calling callSession.setMicState('muted') but that method does not exist on the session object. The default UI mute button works fine, which confirms the agent permissions are correct. It seems the SDK method is rejecting the call for a reason we cannot pinpoint. Is there a specific state check we need to perform before calling muteMic? Or is this a known limitation in the current SDK version?
Is the agent actually in a connected state, or just ringing? I see this error a lot when the call hasn’t fully established a media stream yet.
The Embeddable Client SDK doesn’t just take a command and fire it at the server. It checks the local session state first. If the state isn’t connected, muteMic throws that operation not allowed error because there’s no active media path to toggle.
Check the documentation for GenesysCloud.Client. It states:
“The muteMic method can only be called when the client is in a connected state. Calling it during ringing or disconnected states will result in an error.”
You need to listen for the state change before you allow the mute button to work. Here is how you handle it properly in the JS SDK:
const client = GenesysCloud.Client;
// Listen for state changes
client.on('stateChange', (newState) => {
 console.log('Client state changed to:', newState);
 if (newState === 'connected') {
 // Only now is it safe to mute
 enableMuteButton();
 } else {
 disableMuteButton();
async function handleMuteToggle() {
 // Check current state explicitly if you aren't using the event listener
 const currentState = client.getState();
 if (currentState !== 'connected') {
 throw new Error('Not connected');
 await client.muteMic(true);
 console.log('Mic muted successfully');
 } catch (error) {
 console.error('Failed to mute:', error);
If you are already connected and still getting it, check your OAuth scopes. The embeddable client usually handles the token internally, but if you are wrapping it in a custom auth flow, ensure client:call:write is included in the token scopes. Missing that scope often results in generic “not allowed” errors instead of a proper 403.
Don’t fight the SDK’s internal state machine. It’s designed to block that call to prevent race conditions, so you’ll get burned trying to bypass it. Just bind your button to the onMicStateChange event and let the SDK handle the toggle.
