Any9one had an issue whereby the stats are not being gathered before the first session of CCPUlse is run during the day. Our stats should collate from 12:00am onwards, but it appears that they only begin to collate once the first user of CCPulse opens the application.
I believe this is some sort of timeout issue. Statserver will only count stats that have been requested of it ie when ccpulse starts up and says give me the stats for these agents. I think, if there is no change in an agent stat for a certain period then statserver will stop counting, until asked again.
Documentation recommends that the OldStatsRemoveInterval is set to 4320 (3 days). The value should be minutes expressed as an interger. Changes take affect when the Stat Server is restarted but shoul not be changed when StatServer is running.
This sets the amount of time in minutes that the stats should continue to calculate on Stat Server.
