CCPulse and virtual groups
We have an issue with CCPulse and updating virtual agent groups.
We use a logged in script, rather than skill expressions in our virtual groups for certain agent groups and when TL’s attempt to use the “Dynamic” view the agents will appear correctly to start with, but as they log in and out the agents do not move from 1 group to another.
Has anyone else experienced this?
Which version are you using Dionysis?
7.5 CCPulse and 7.6 everything else. :slight_smile:
Have you configured the CCP application in CME with the following option under Workspave section
UseStatServerVirtualGroups=true
Yes. Without this option set the virtual groups don’t work at all.
They work for me, but just don’t keep up with agents changing states.
Example:
Agent working in processing group A (on Alcatel 4400)
Agent logs out using desktop application
Agent logs in to processing group B.
This all happens in succession, all automated by the desktop application.
In CCPulse monitoring a virtual agent group with the script “LoggedIn(“ProcessingGroupA@Alcatel4400”)”, we see the agent log out for a split second and then straight back in.
According to CCPulse the agent is still in the original agent group, but in Stat Server logs they are not. If the CCPulse view is closed and re-opened the agent disappears from the agent group, and is added to another if there is one for Processing Group B.
It seems that CCPulse is only updating based on the status once it has it’s list of agents for the virtual group, and not re checking group membership.
kinda workaround :wink: but works for me
  1. Create skill “CCPproblem”
  2. add it to all Agents
  3. In CME edit Processing Group script and put
    SkillExists(“CCPproblem”) & “LoggedIn(“ProcessingGroupA@Alcatel4400”)”
In my case VAG group update in CCPulse worked properly
You do realize this question is almost 3 and some months old, right? :wink:
Enthusiastic poster we have now
3 months Cav?? I think you mean 3 Years :smiley:
Woops I ate the word year, it was “3 years and some months” :stuck_out_tongue:
