CCpulse action problem
How do you hide logged out agents in the object view in CC Pulse?
Answer/Resolution:
  1. Create the following thresholds:
Check Login <------------------- This is the threshold name
if Threshold.StatValue = StatAction.SDNALoggedIn then
Threshold.Result = true
else
Threshold.Result = false
end if
Check Logout <------------------- This is the threshold name
if Threshold.StatValue = StatAction.SDNALoggedOut then
else
end if
  1. Create the following actions:
ShowAgent <------------------- This is the action name
CCPulseNotifier.Show
HideAgent <------------------- This is the action name
CCPulseNotifier.Hide
  1. Create a workspace with Agents in the Object tree
  2. Select several Agents in the Object view, rightclick, select Threshold
from the popup menu.
  1. Assign the thresholds/actions
  2. Press OK
  3. Test it
It should now hide logged out agents in the object view.
I did this steps, but whan I want to create action “CCPulseNotifier.Hide” I got an error: object doesn’t support this property or method: “CCPulseNotifier.Hide”
Where is may mistake?
With a CCPulse version 6.1.000.03 it works.
No error is detected.
hello.
Can it work with 5.2?
I tried, and it works only from 6.1 version.
I don’t believe it works in the same way in 5.2 as in 6.x. There is a way but I’m sure its a bit of a ‘hack’. Look at the FAQ’s on Genesys website the answer is there.
