Calling List Filter Problem
Hello Everyone,
We are using calling list filter for call different user groups in list. Sometimes in a calling list we may have 5 filters.
We select a filter and start call process but sometimes genesys passes the active filter and makes a call from another filter like we don’t use any filter.
  • Data is checked
  • Also we send filter parameter to workspace screen to make sure that call comes from another filter.
If anyone help me, I will be very glad.
Thank you.
That can’t happen…do you have OCS logs? There will be shown the sql queries used and filter values.
Also dbserver ones.
You can’t have more than 1 filter applied at each time. Or maybe your where clauses are the wrong?
Check and post logs to validate
Here sql log taken from OCS Logs
“select T.* from #ReadyRecord R, KGS_Istanbul T where R.chain_id=T.chain_id and T.record_status = 2 and (filter_first = ‘firma1’ AND contact_info_type = 1) order by T.chain_id,T.chain_n [ReqID=9890895]”
belowed one is our filter.
https://imgur.com/a/vt1z7
Full OCS logs, can’t see if filter was applied or what
Hi again,
I sent log files with private message. Problem occurs in DF2 Calling list generally but filter not matters, any filter can cause the problem. If you need anything, I can send it you.
Thanks.
post them here, remove any sensitive info. I can’t dedicate and maybe someone else can look at it too.
If you want dedicated support I can send you my paypal account :wink:
