Call monitoring, Silent, Whisper, Barge
we are having a problem with this. We can get it to work, but in all cases:
Screen pop was still very slow for the supervisor unless skills matched the agent. 30 secs +. With skills matched it is 3-4 secs.
A customer cannot be retrieved (by the agent) after being put on hold. When retrieve is attempted the call remains open, but the agent loses it – the customer and the supervisor remain connected. What seems wrong with this is that it suggests that these functions cannot be used in a live situation, as using hold is a commonplace event.
Have we missed a simple parameter here? Anyone else using these live and not dropping customer - agent connection?
Hi David,
I don't see any relation between mentioned features (call monitoring) and screen-pop. I think you should check your agent desktop application if screen pop-up takes so long.
I think I've already heard about similar issue but not 100 % sure. Can you upload your SIP Server log so I can see what happens to the call?
Rene,
I can’t seem to post the log in the message body - is there a restriction on size?
Is there some other way to get it to you?
David
Hi David,
Unfortunately, upload functionality is disabled on this forum. Please upload the logs somewhere and post the link here.
PS. To Admins - guys, are you going to fix upload in near feature? :wink:
