First I’ll start out apologizing for not searching thoroughly for an answer…
Problem is I have no idea what to search for, I’m an Aspect guy not a Genesys guy.
So here is what I’m trying to do, I need to build a document that has the following:
TFN, DNIS, CCT, Welcome Greeting, Queue announcements, Closed announcement, Meeting announcement and Holiday Announcement
I can pull TFN, DNIS, CCT from the Aspect ACD’s back end database pretty easily. But the rest is controlled by Genesys. The Genesys admins here gave me access to Config manager but that is such a tedious process. Tools → Find → DN ->enter cct number. Double click routing → click Annex → double click ROUTER → Re type everything under name/value because I can’t copy out and paste into excel.
It’s even tedious to type the process
So they gave me the TNS entry and login for the back end oracle database. They didn’t know the answer and looking through the schema I can’t find it but here is the question.
Is there a SELECT query that I can run that will pull DN, everything in the Annex section of the config manager. Preferably all in 1 record but if each DN has to have a record for each seperate annex entry then I can handle that as well.
One would hope this would be easy but I dunno where to start :-/
I am sure it is possible, I did something similar (with help from here) in Brio. Pulled back the config tables and found the DN table, linked it to the config_options and pulled back the router section.
I’ll see if i can find some more information than that for you!
Also, you should be able to export from the DN in CME. Export to a cfg file, open and copy contents to excel :]
Below is SQL code that allows you to retrieve list of all options stored on Annex tab in the section “ROUTER”. Format of the output is:
SELECT dn.number_ AS DN,flex2.prop_name,flex2.prop_value
FROM CFG_DN dn
LEFT JOIN CFG_FLEX_PROP flex1 ON flex1.object_dbid = dn.dbid
LEFT JOIN CFG_FLEX_PROP flex2 ON flex2.parent_dbid = flex1.dbid
WHERE dn.TYPE=4 AND flex1.prop_name = '__ROUTER__'
ORDER BY DN,flex2.PROP_NAME
