Call associated with wrong agent in Info Mart
Strange one this…
Several calls in Info Mart’s CONTACT_ATTEMPT_FACT table are linked with the wrong resource. It looks like when a supervisor is silent monitoring agents, the call is being linked with the supervisor rather than the agent, so in the database it looks like the supervisor made the call.
I’ve confirmed this by checking the calls in the call recording software and can see which agents actually made the calls.
Is this some kind of routing issue or is there some option I don’t know about that will control this behaviour?
Hi Adam,
What version of GIM do you have? Anyway, it seems to me like limitation of GIM so I would suggest you contacting Genesys Technical Support.
Regards,
René
Hi René
It’s version 7.6.005.12. I’ve logged it with Genesys so will see what they come back with :slight_smile:
