Hi John,
I had my own version of this a while back. To display all results from the previous day, the SQL for the Request Section would be;
CASE WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-1,12) THEN 1 ELSE 0 END
Similarly, for Oracle:
DECODE(T_xxx_Time_Dim.Date_Yyyymmdd, TO_CHAR(SYSDATE-1,‘YYYYMMDD’),1,0)
Then, in the Limit Section of the Brio Query, drag in the Request Statement created above and enter 1 for yesterday’s date as the selection criteria.
You can play about with the GETDATE()-1 or SYSDATE-1 to get the desired results for one day, two days, three days previous, etc. but that won’t give you a date to date range - just a full day’s results based on today’s (system) date.
If you want a range, try creating a series of statements from above (one with -1, another with -2, etc.) and place them in your Limit criteria as an OR (not AND) Statement…
Oracle version (Checked):
DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-1,‘YYYYMMDD’),1,0)=‘1’ OR DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-2,‘YYYYMMDD’),1,0)=‘1’ OR DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-3,‘YYYYMMDD’),1,0)=‘1’ OR DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-4,‘YYYYMMDD’),1,0)=‘1’ OR DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-5,‘YYYYMMDD’),1,0)=‘1’ OR DECODE(AL3.DATE_YYYYMMDD, TO_CHAR(SYSDATE-6,‘YYYYMMDD’),1,0)=‘1’)
SQL (Not Checked):
CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-1,12) THEN 1 ELSE 0 END)=‘1’ OR CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-2,12) THEN 1 ELSE 0 END)=‘1’ OR CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-3,12) THEN 1 ELSE 0 END)=‘1’ OR CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-4,12) THEN 1 ELSE 0 END)=‘1’ OR CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-5,12) THEN 1 ELSE 0 END)=‘1’ OR CASE (WHEN T_xxx_Time_Dim.Date_Yymmdd = CONVERT (char,GETDATE()-6,12) THEN 1 ELSE 0 END)=‘1’
OK, so I’m sure there’s a better way with a BETWEEN Statement but it’s Friday afternoon and I have checked that this does the job in Oracle! ;D
Tony
