Brio Reports - How to design them
I was trying to design some Brio reports but sheer number of fields/columns is overwhelming. Does anyone know of a good document to outline the fields I should use?
the Brio enterprise user guide gives a good overview on how to build reports.
then to select the fields, it all depends what statistics you want to display : you have relationships between the tables
Try my Rough Guide - search for;
007 - ROUGH GUIDE TO CCA AND HISTORICAL REPORTING v7.x
Tony
