If you developed the Brio Report on your Desktop PC, where are your .BQY Files situated? Are they in the default directory, where the Broadcst Server requires them?
Is the Brio Query running with an associated .oce file and is that file located where it should be?
Is your Report constraining itself to be invalid. Run it manually and see if it produces results.
Get back to me and I’ll probably have thought of a few more scenarios to check…
Job storage location is defined as Database.
Yes.
Running report manually give me correct values, so there is nothing wrong with BQY file.
It would be easier if you copied them out and check the differences between older ones (which do work) and newer ones (which don’t). If you get the opportunity, please copy them off and send them to my email address.
What is a BCS? Have you changed the Server? If so, you will need to define it inthe Broadcast Server setup.
