Automatic Start Solution
Hello
It’s possible to start the solution automatically
in Framework 7.X
Regards
Ben
Ben,
“Solutions” are dependant on an Event and a correpsonding Action. For an “Application”, the same parameters exist in SCI.
What Solution/Application are you trying to automate and what are the circumstances?
Are you referring to SCI to restart your Solutions or the OS to start an Application, independant of SCI?
we have an gexpress 3.2 (base on 7.1 framework) voice and email routing
the question is, after reboot the pc it’s possible to start automaticly the solution
at this time we open sci and start the solution manual on sci
is there any way to do this?
SCS 7.0.1 autostarts applications on host upon it’s restart or reconnection to host if the proper options are set up, please take a look at the Release Notes and the latest 7.0 Manuals on the Tech Support Web Site.
You can always start the apps as services, with a startup type of automatic.
If you want things to start in a particular order, create a batch file that calls the apps in the order you want them to start. You can then add a reference to this batch file in HKLM/Run.
