AttributeOtherQueue info in IRD (8.1)
Hello all, hope everything’s ok around there. As in object, is the AttributeOtherQueue information obtainable to be used, inside IRD?
Best regards.
Hi Gef,
It should be possible using GetRawAttribute function. See details in documentation as it is no just about using that function but URS configuration must be updated as well.
Thank you René, I will read docs for that.
Ok, implementation is clear, but can’t find a complete cross reference list between attribute and number to set. Any clue?
Here is link - https://docs.genesys.com/Documentation/PSDK/9.0.x/TlibRef/TAttribute
Index of first item is 0 (zero)
Thank you very much, René, stay well.
