Since I (still) cannot attach graphics, here is a narrative;
ALWAYS TRY OUT EVERYTHING BEFORE YOU APPLY IT IN YOUR PRODUCTION SYSTEM!
METHOD:
Add sub-folders under the following Resources and drag/drop the relevant sub-sub-Folders into each one, according to the Solution-type;
Agent Groups>Voice>(Agent Groups)
Agent Groups>Multimedia>(Agent Groups)
AND
DN Groups>Voice>(DN Groups)
DN Groups>Multimedia>(DN Groups)
AND
Persons>Voice>(Persons)
Persons>Multimedia>(Persons)
AND
Place Groups>Voice>(Place Groups)
Place Groups>Multimedia>(Place Groups)
AND
Places>Voice>(Places)
Places>Multimedia>(Places)
AND
Skills>Voice>(Skills)
Skills>Multimedia>(Skills)
Create a Username (Person) configured with access removed for all of the Multimedia Folders (Called “Voice Only”). Do this by navigating to all of the Resources>Multimedia Sub-Folders, right-click them and update the Security>Permissions options, adding the Voice Only Username then select “No Access”.
Create a Username (Person) configured with access removed for all of the Voice Folders (Called “Multimedia Only”). Do this by navigating to all of the Resources>Voice Sub-Folders, right-click them and update the Security>Permissions options, adding the Multimedia Only Username then select “No Access”.
Identify the Applications which are ONLY Voice (and do not need access to Multimedia Resources such as DN Groups, Agent Groups, Place Groups, etc.) - this may include identifying Config Proxies too - and restart them, using the “Log On As” Username Voice Only. Do this by navigating to the Application(s) in the Environment Section and click on the Security Tab - then navigate to the “Log On As” section and updated the “SYSTEM Account” to “This Account” and select the Username Voice Only.
Identify the Applications which are ONLY Multimedia(and do not need access to Voice Resources such as DN Groups, Agent Groups, Place Groups, etc.) - this may include identifying Config Proxies too - and restart them, using the “Log On As” Username Multimedia Only. Do this by navigating to the Application(s) in the Enviornment Section and click on the Security Tab - then navigate to the “Log On As” section and update the “SYSTEM Account” to “This Account” and select the Username Multimedia Only.
RESULTS EXPECTED:
The end effect is that the Applications for Voice should only be servicing Voice components and the data throughput is greatly reduced, since it is not “aware” of Multimedia components/objects - and vice versa for Multimedia Applications.
This, overall, shoud add a massive amount of stability to the overall Platform by ensuring the Framework and Solution Applications are constrained to their own Solution objects and statistics, etc. - and are not operating with a high volume of messaging for objects and statistics which it does not use.
- Let me know if this makes sense, anyone…? lol
TT
