Could someone clarify why the agent scripting api returns a 504 gateway timeout when jmeter threads exceed 150? we are running gc version 2024-12. the endpoint is for agent scripting. it works fine with low concurrency but fails consistently at scale. is there a hard limit on scripting requests per second we are hitting? need to adjust our test plan.
Check your request payload structure and the specific scripting engine version being targeted. The 504 Gateway Timeout when calling the scripting API is rarely a hard rate limit issue at 150 concurrent threads. Instead, this usually indicates that the backend service responsible for parsing the script definition is hitting a processing bottleneck or a silent timeout due to complex nested conditions or large attribute mappings within the script payload.
When running load tests against Genesys Cloud APIs, especially for heavy operations like scripting or WFM publishing, the default timeout values in your load generator (JMeter) might be shorter than the platform’s internal processing window under load. The platform API enforces soft limits that scale with your organization’s tier, but the 504 specifically suggests the gateway gave up waiting for a response from the upstream service.
To mitigate this, consider implementing exponential backoff in your JMeter script. Instead of firing all 150 threads simultaneously, stagger the requests. Here is a sample JMeter BeanShell pre-processor snippet to add a randomized delay before each request:
import java.util.Random;
Random rand = new Random();
int delay = rand.nextInt(500) + 200; // 200-700ms delay
Thread.sleep(delay);
Additionally, verify if the scripts being deployed contain any dynamic data lookups or external API calls within the script logic itself. If the scripting engine needs to resolve external variables during the publish or update action, this adds significant latency. Simplify the script payload for the load test to isolate whether the issue is the API endpoint throughput or the complexity of the script content.
Note: Ensure your service account has the ScriptAdmin role. While this typically results in a 403, permission checks at scale can sometimes trigger unexpected gateway behaviors if the auth service is under heavy load.
My usual workaround is to looking at how the scheduling backend interacts with the scripting engine during peak load, especially when adherence rules are active. While the previous suggestion about payload complexity is valid, we often see timeouts when the WFM schedule group is being updated or validated concurrently with high-volume scripting requests. The system tries to reconcile agent availability states with the new script assignments, causing a bottleneck in the interaction service. Try isolating the schedule publishing window from the load test execution. If your agents are in a “Scheduled” state during the test, ensure the adherence engine isn’t recalculating availability for every script node hit. We noticed that disabling real-time adherence updates during the test window resolved the 504s for our Chicago team. It’s not always the script itself, but the side effects on the workforce management data layer that choke the gateway under heavy concurrency.
